Shadow bias default value is too high for Vray lights, causes artifacts
  • Shadow bias default value is too high for Vray lights, causes artifacts
    This took me a while to figure out, I had weird artifacts in my contact shadows like this
    Going down on shadow bias to .0002 fixed the issue
    The default value for shadow bias in other Vray plugins is 200 μm
    In VFH it is 2 mm by default which is quite high and causes the artifacts I showed above.
    I really think it should be .0002 by default instead of .002 for all lights..
    This took me a long while to figure out, I thought it has something to do with my SSS or light leaking because of geometry overlapping.
    If you think the behavior might be a bug, I can upload my scene. The apples are real world scale, around 5 CM tall
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    yes, absolutely yes! I just kept turning it down all the time (did for some reason not report it).
      +1 from me
      http://goodbyekansasstudios.com/
        In maya the default is .02, I almost always set it to .002 for medium to close shots.
        www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
          Maya uses CM by default, .02 in Maya is .0002 in Houdini
          Houdini and Modo use Meters
          Muhammed Hamed
          chaos.com
            I've added the request.
            Georgy Chakarov | QA
            www.chaosgroup.com
            georgy.chakarov@chaosgroup.com
              Thank you!
              Muhammed Hamed
              chaos.com
