I'm using a Vray file node, with UV type set to environment and I linked that to my Domelight
Using the horizontal rotation slider, doesn't update in the IPR. I'm sure this used to work at some point before
rotating my HDRIs is very important in look dev to see how my shaders are holding up.
I also tried to use the rotation tranforms on the Domelight itself. It also doesn't update in the IPR
And while we are at this, is it possible to have color space changes update in the IPR?
The one in the bitmap tab of the Vray file node. This is going to help with look dev as well
Some textures I can just change their color space instead of using a curve color correction, which saves time
Thanks!
Houdini 17.5.380
Latest nightly
Best,
Muhammed
Thanks!
Houdini 17.5.380
Latest nightly
Best,
Muhammed
