Softbox changes not updating in IPR
  • Softbox changes not updating in IPR
    Hi guys,
    I am working with softbox textures in Area lights. Changing the paramenters of the softbox doesnt update the IPR rendering. must restart IPR to reflect the changes.
    softbox is in a matnet in /obj and the path is added in the texture path of the Use Texture option in the area light.
    This used to work in the initial release in the end of july. (we just tested that)
    I am on the nightly build number 5335 of the 1st of october.
    I tested the stable build from today, build number 5342, in which this also doesnt work.
    Would be great to see this working again!
    (cant seem to uplaod a file, if you need one, please let me know, i can send it somehow else)
    It also seems that camera animation update in ipr is also broken (this is today stable) . Have there been any major changes to ipr because this used to work pretty nicely in the release version (which is the version I've been using for production until recently).
      Yes, other that fixing bugs, support for updating displacement in IPR was added recently. Changes were also required for the Forced/Candidate objects, display flags, subnetworks, etc.
      We'll start including a change log soon so you guys can keep track of what is going on.
      Thank you both for the the heads up. I'll be logging those issues and will ping you when they are resolved.
      gosho.genchev@chaosgroup.com
        Thanks Gosho!
        This will help quite a lot!
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
