viewport diffuse texture display
  • viewport diffuse texture display
    At some point displaying diffuse textures on vray material was somewhat working, not more. VrayMaterialBuilder viewport shading tab, does not seem to enable the texture in viewport, even when i select that texture file there, and path is expanded correctly in that drop menu. It renders fine, but nothing in viewport...
    Then there is SOP node called VRay_viewporttex, that also does not seem to work. It always displays yellow, as UV missing warning, even when there clearly are uv and stuff renders with texture...,.Changing setting on that node, loading material from atrribute or directly selecting it from that node also does not help.
    Noemotion.net - www.noemotion.net
    Peter Sanitra - www.psanitra.com
    Noemotionhdrs.net - www.noemotionhdrs.net
    Yup, the Material Output node inside has to be assigned, not the Material Builder itself. We need to find a good way to handle this.
    I'll check what's going on with the SOP node.
    Thank you!
    gosho.genchev@chaosgroup.com
      Hi psanitra , I just checked ViewportTexSOP it supports V-Ray Material Builder and V-Ray Material Complex. Because of some small changes in V-Ray Builder node it's not working correctly with it. Hou-1242 is the bug number if you want to check our progress on it.
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
