ipr bugs
  • ipr bugs
    nightly vray_adv_42090_houdini17.5.293_464e2ff_5454_window s
    - Runnig IPR from VFB by pressing play button is broken. Geometry will not load/update properly when changing time/frame. It will update only the geo for object fastest to load, the rest will not update. For example loading 2 Gometry nodes, one have 5000 particles, other have 50 0000. As soon as the lighter loads, IPR starts to render, the heaview will never update.
    This is only broken for VFB button ONLY. When running same scene with houdini rendering view tab, it will update scene correctly.
    - after running IPR from VFB, and finished or stopped, running it again with play button will actually hide the VFB and render, instead keeping it open and rendering...
    Noemotion.net - www.noemotion.net
    Peter Sanitra - www.psanitra.com
    Noemotionhdrs.net - www.noemotionhdrs.net
    I've noticed the opposite recently - changing the frame will force an update if a parameter change did not (e.g. Scatter SOP number of points). I'm logging it ( HOU-1275) but a scene where this happens (changing frame not updating IPR) would be much appreciated.
    This is logged as HOU-1259.
    Thanks for letting us know about these issues.
    Cheers!
    gosho.genchev@chaosgroup.com
