multiple render node workflow
  • multiple render node workflow
    WHen i'm working on rendering differents passes, i like to use different renderer node.
    When i'm opening IPR, i have automaticly the 2 wich open. Ok why not it make sense.
    But i can't choose the one i want to render, it's always start the first in alphabetic order.
    So i deactivate the one i don't want to work with right now.
    IT's always open the 2 Ipr windows and start the first one in alphabetic order.
    It's a bad workflow or there is a better way to do this ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    the one wich start to render is the deactivated one.
    freelance 3D artist
    www.ghiom.com
      The V-Ray IPR ROP has a separate field used to specify the Renderer ROP that should be used. It's essentially a dummy node. I agree the issue you've described should not be happening but we need to think about a better workflow for IPR / VFB in general. We have a few suggestions so far, among them merging the ROPs, or adding a right-click option for the camera on the VFB.
      Thank you for bringing this up. I'll ping the dev team to see how we can improve the workflow.
      All the best!
      gosho.genchev@chaosgroup.com
