[HOU-1360] Alsurface SSS doesn't show through glossy refractions.
  • [HOU-1360] Alsurface SSS doesn't show through glossy refractions.
    I am not sure if I should post this in another forum but for now I am posting this here since as far as I am aware vray for Houdini doesn't use the most up to date standalone version of vray.
    The issue I am having and that happens in vray for 3ds max as well is that if I have an object with the alsurface material behind a glossy refractive glass object the sss is gone.
    I uploaded a few screenshots that demonstrate the issue.
    I hope this is something that can be fixed in a timely manner or maybe there is a workaround because this would be needed for an upcoming job.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    Thanks for the pointer; looking into it. I recently fixed something similar for the flakes material, I'm guessing it's a similar problem.
      Thank you Vlado for the feedback! Hope this isn't a complicated fix.
      In theory though if this is getting fixed relatively quickly. How long would it take to appear in the nightlies for houdini and max?
      Cheers,
      Oliver
        Vlado fixed the issue last evening - it's already available in the 3ds Max nightlies. We need to grab it on our side so its available in V-Houdini too - it shouldn't take more than a couple of days.
        All the best!
        gosho.genchev@chaosgroup.com
          Oh awesome!. Thank you for the update. I'll wait for the fix to arrive for the houdini version then
          Cheers,
          Oliver
            Try the latest 4.3 nightly it is already there.
            andrei.izrantcev@chaos.com
            Support Request
              Oh that is great news! Sadly I might not have access to those I only see 4.12 (stable) for Houdini on the nightlies homepage.
              Do I need to contact chaos group support?
              Cheers,
              Oliver
                Yup, send support@chaosgroup.com an email.
                Cheers!
                  Will do! Thank you.
                  Cheers,
                  Oliver
