Issue vrscene single vs sequence
  • Issue vrscene single vs sequence
    Hi guys,
    we just ran into an issue where rendering lines on the farm (standalone) work only when writing out vrscenes in a sequence and not in a single vrscene.
    see example file attached. there are 2 ROPS, one writes a single vrscene and one a sequence.
    can there be some mismatch between the standalone on the farm and the plugin?
    thanks!
    vray: Build number:5763 hash:565d8ca from 15 Nov 2019 04:16
    houdini 17.5.293
    farm is rendering vray 4.12 standalone from the 27th of september
    Hello jurweer , because of the constantly updating VFH you should definitely update your V-Ray standalone. I'll take a look at scenes in your last two posts and will write back when I know something more.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Thanks chakarov !
      Updating is currently not an option as were in the middle of multiple projects. Were there any fixes on StandAlone? Its a bit difficult to track what plugin to use with which standalone when there is no changelog docs
        jurweer, use Standalone shipped with VFH.
        andrei.izrantcev@chaos.com
        Support Request
