mutli id texture don't seem to work at all
(Fixed) [HOU-2364] mutli id texture don't seem to work at all
Tags: None
I'm not sure I could understand/fix anything from the screenshot of the node... but I'll try to post a screenshot myself
1 Photo
- Likes 2
sorry a bit lazy in the evenings :P
whatever i choose in "mode" dropdown i dont get any effect not even the default texture color. Kinda feels like the node not outputting any color at all. Even if i do as you and connect a user float with attribute nothing happens.
edit: the cubes have 0, 0.5, 1 in float value respectively2 Photos
Multi ID texture is choosing an input texture based on "Mode" and you don't have any input textures connected.
1 Photo
- Likes 1
Here is another example by face attribute sampled with "user float":
1 Photo
I thought it would work as the multi sub in 3ds max https://docs.chaosgroup.com/display/...RayMultiSubTex. there you can choose based on object or renderid and get a random value. If that's not the way that node works i misunderstood.
Btw is there a way to take an integer id and convert it to a random float between 0 and 1?
Regards Alexis
The Explicit UVs do what the name implies - set the sampling coordinates to an explicit U/V value.
If you then plug your attribute into the sampled position, you should get a random piece of the noise for each attribute value.
If that is not what you were looking for, please ping me so we can try to think of something else.
I've attached the hip file here: https://drive.google.com/file/d/1WiD...ew?usp=sharing
Cheers!
this example does helpBut im curious if we could get a mode suited exactly for randomizing integers or float. We do it alot on particles and scattered object in vray houdini. Especially getting a seed so we can quickly get different outputs for diferrent shading values. for example hue, saturation and value.
the images are from mantra which we use all the time.
Regards Alexis2 Photos
this example does helpBut im curious if we could get a node suited exactly for randomizing integers or floats. We do it a lot on particles and scattered objects in vray houdini. Especially getting a seed so we can quickly get different outputs for different shading values. for example hue, saturation and value.
For setting per geometry island variation with the multi ID texture, I'm assigning an integer value to every connected primitive using a "connectivity" node, then feeding that parameter to the multi id texture using a user integer/float. This works but it's an additional step, would be nice to get an option in the multi id texture/material to do this, also with a seed option.
The radom node would just create a random number, you still need that random generator to run a loop through out all your primitives, connected geo, points, etc. If that random node have the option to create random values for specified condition, like Primitives or connected geo, that would be great.
Also what about random texture rotations per geometry island?
Best,
David.David Anastácio // Accenture Song - VFX
https://www.accenture.com/us-en/serv...visual-effects
There is an input/param in the named uvwgen for that.
- Likes 1
bdancer, of course ahahah, thanks that was so easy, works like a charmDavid Anastácio // Accenture Song - VFX
Muhammed_Hamed, that's a very good looking floorDavid Anastácio // Accenture Song - VFX
- Likes 1
