[HOU-1554] vfb crashes
  • [HOU-1554] vfb crashes
    We get crashes and freezes when rendering with ipr and vfb on many occasions. Its hard to track exactly when or why so I was thinking of putting up one example here for now.
    Because these crashes and freezes are a bit random we only sometimes have a crashlog. What informationen do you usually want for these kind of errors. Maybe a debugging tool tracking memory or something?
    Regards alexis
    this one crashed when selected framebuffer window and dragged it
    http://goodbyekansasstudios.com/
    I reported this a while back, Gosho found out that it is related to running low on system memory
    This is how I got it to crash on my laptop..
    https://www.youtube.com/watch?v=kYHZZPPybJE
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      i get a crash every other render in my scene:
      terminal:
      2960: Fatal error: Segmentation fault (sent by pid 368271652)
      Saving application data to /tmp/houdini_temp/crash.ursa_assetbEnv_mainstreet_main_aleand_v020.a lexis.andersson_2960.hip
      [2020/Jan/20|16:02:55] VFH | Error| * Geometry node not found!
      Spawn Error: : No such file or directory
      Error running xmessage
      Argument list:
      0: xmessage
      1: Fatal Error: data saved to /tmp/houdini_temp/crash.ursa_assetbEnv_mainstreet_main_aleand_v020.a lexis.andersson_2960.hip
      Crash log saved to /tmp/houdini_temp/crash.ursa_assetbEnv_mainstreet_main_aleand_v020.a lexis.andersson_2960_log.txt
      sh: xmessage: command not found
      log and scene without alembic file:
      https://drive.google.com/drive/folde...9J?usp=sharing
        Hello LeoYfver , I couldn't reproduce the crash on my side with your or newer nightly build, but I've got the same error "* Geometry node not found!". Issue is reported as HOU-1554 and will inform you when we know something more.
        Georgy Chakarov | QA
        www.chaosgroup.com
        georgy.chakarov@chaosgroup.com
