No Vray with custom HOUDINI_USER_PREF_DIR
  • No Vray with custom HOUDINI_USER_PREF_DIR
    I have Houdini 18.0.308 working with the latest nightly vray_adv_43000_houdini18.0.279_20cdd59_5950. Nice!
    But to easily manage multiple machines (workstation and rendernodes) with the same prefs, houdini.env, vray install,... I'm trying to centralize
    I created a new User Variable for HOUDINI_USER_PREF_DIR with value E:\_Houdini\_Configs\houdini__HVER__
    This seems to be working for the most part except for Vray. When starting Houdini, Vray has disappeared.
    I noticed that, unlike earlier (beta)versions, with these newer installers, nothing is added to the houdini.env anymore. So I'm guessing I should look else where, but where?
    Cheers,
    Tim
    Hey there,
    package files are used when running the installer. Those are located in the Houdini install folder, e.g. C:\Program Files\Side Effects Software\Houdini 17.5.391\packages
    Nothing has changed regarding the zip version - you can grab an example environment file from an old build, or check the unpackedZip/docs/vray_for_houdini.json file for the environment variables setup.
    Please ping me if you hit any issues setting things up.
    Cheers!
    gosho.genchev@chaosgroup.com
      Hi Gosho,
      Thanks for your quick response!
      Simply copying these lines into the houdini.env did the trick:
      Code:
      # V-Ray for Houdini Begin
      VFH_ROOT="E:\_Houdini\vray_for_houdini_18"
      VRAY_APPSDK="${VFH_ROOT}/appsdk"
      VRAY_OSL_PATH="${VRAY_APPSDK}/bin"
      VRAY_UI_DS_PATH="${VFH_ROOT}/ui"
      VFH_HOME="${VFH_ROOT}/vfh_home"
      VFH_PATH="${VFH_HOME}/bin;${VRAY_APPSDK}/bin"
      PATH="${VFH_PATH};${PATH}"
      HOUDINI_PATH="${VFH_HOME};${HOUDINI_PATH};&"
      HOUDINI13_VOLUME_COMPATIBILITY=1
      HDF5_DISABLE_VERSION_CHECK=1
      # V-Ray for Houdini End
      Cheers,
      Tim
