hierarchy preference in objectProperties/visibility
  • hierarchy preference in objectProperties/visibility
    when a subnet with a geo inside both have object properties/Enable Visibility Options enabled. The top node(subnet) has precedence. I think the preferable way is the other way around to be able to have granular control.
    For example if I have a subnet which I want to disable the Primary Visibility off and have 10 objects inside which one of them I want on I cant do it right now.
    What do you guys think?
    I will also add that for subdivision it gets more complicated. Because its only on or off the only way is to control it on the subnet. So if you want 1 object inside your subnet to have subdivision it wont be possible. I unfortunately dont have a solution that i can present except to be able to enable/disable every tab in the objects properties which isnt the best solution.
    https://drive.google.com/file/d/19xH...ew?usp=sharing
    Regards Alexis
    http://goodbyekansasstudios.com/
