(Fixed) [HOU-1218] Added Parameters in Material Builder not being resolved
  • (Fixed) [HOU-1218] Added Parameters in Material Builder not being resolved
    Hi. In duplicating a setup we were using in Redshift, we've found that v-ray render is not resolving some variables. See attached files. All four should render, and in fact all four paths are found and displayed in the viewport. But only when we replace $OS (or ${OS}) in the custom Texture Name field with the explicit name will the texture render properly.
    path_expression.zip
    https://www.dropbox.com/s/9f2zdmqsh7...ssion.zip?dl=0 Click image for larger version  Name:	Capture.JPG Views:	1 Size:	401.7 KB ID:	1057379
    Hello corestudio , this seems to work with latest builds. There was an issue with complex expression similar to what you have in the scene some time ago, but it is fixed. What is your V-Ray build?
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Will check the build this morning. I thought it was the most recent stable but not positive.
        Yep, looks like it's fixed in the latest nightly. Thanks!
