Parameter expressions not evaluating in vrayLightDome
  • Parameter expressions not evaluating in vrayLightDome
    Hi!
    Im trying to reference a texture from one place in Houdini into the texture parameter of the vrayLightDome using an expression.
    The expression looks like this:
    Code:
    `chs("../../myNode/file")`
    I can see that the string evaluates correctly in Houdini and I can see the texture on the dome in the viewport but I cant get the texture in the render. It appears to not evaluate correctly on render.
    Cheers!
    Head of Lighting @ Goodbye Kansas Studios
    Ok so I narrowed it down a bit. It turns out that it was the path in myNode.file contained an environment variable, $SHOT_ROOT.
    Like I said. the path is evaluated in Houdini but not when rendering.
    Attaching a simple scene:
    vray_expression_evaluate.zip
      Everything is exported correctly. Check your file path.
      andrei.izrantcev@chaos.com
      Support Request
        Got it working now. Not sure why it wasnt working before. The path was indeed correct in the vrscene.
        We had a frame number in the filename. removing that from the filename solved the problem.
        Thanks for looking into it!
