(No Change Required, Closed) [HOU-1693] [HOU-1673] Batch rendering workflow needs to be fixed
  • #31
    without $OS it is fine.
    export path then:
    VFH [Info] * Starting export to "Y:/Projects/X666_Tryouts/02_WORK/HOUDINI/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/X666_Tryouts_sha_TEST_TEST_A_v005_tok/X666_Tryouts_TEST_TEST_A_v005_tok_Main.0000.vrscen e
    the submite adds "Main\Director" to the image path
    2020-04-21 11:12:17: 0: INFO: Executable: "C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe"
    2020-04-21 11:12:17: 0: INFO: Argument: -scenefile="C:\Users\maya\AppData\Local\Thinkbox\De adline10\slave\Otto\jobsData\5e9eb8ea454841243861d af1\thread0_temp9cPYv0\X666_Tryouts_TEST_TEST_A_v0 05_tok_Main.0000.vrscene" -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile="Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\ D_Output\exr\TEST\TEST_A\Main\Director\v005\X666_T ryouts_TEST_TEST_A_v005_tok_Main_slCG.<frame04>.ex r" -numThreads=0
    2020-04-21 11:12:17: 0: INFO: Full Command: "C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe" -scenefile="C:\Users\maya\AppData\Local\Thinkbox\De adline10\slave\Otto\jobsData\5e9eb8ea454841243861d af1\thread0_temp9cPYv0\X666_Tryouts_TEST_TEST_A_v0 05_tok_Main.0000.vrscene" -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile="Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\ D_Output\exr\TEST\TEST_A\Main\Director\v005\X666_T ryouts_TEST_TEST_A_v005_tok_Main_slCG.<frame04>.ex r" -numThreads=0
    this would be okay for now, but where the "Director" come from
    • #32
      "Director" is coming from $OS variable.
      $OS is the name of the node this $OS var is used at, I'll try to figure out why it's not evaluated correctly (Director is the name of the most top context node "/").
      andrei.izrantcev@chaos.com
      Support Request
      • #33
        any news about ?
