overscan locally works fine but when batch rendering we get only the overscan resolution but no overscan. Dont think we change anthing from our side, can you guys check if this is a bug?
I can't reproduce it on my side. I tried with deadline and hython, everything seems to work as expected. Which Houdin and V-Ray version you are using? Can you send a simple scene with the problem to us?
So we have debugged this some more. The reason the overscan is not working is cause we got "ignore_vfb_settings" ticked to not includ crazy grades or other crazy stuff people might be up to in the VFB into the render.
Could we move or add overscan settings to be explicitly set on the VRay ROP?
EDIT: Actually the bug seems to be that VRay do not read the the Screen Window Size from the Camera Shape. Both ways of solving the problem would work for us. So whatever is easiest for you.
