(Fixed) [HOU-1736] vdb in phantom or matte renders as forced
  • (Fixed) [HOU-1736] vdb in phantom or matte renders as forced
    .vdb files in phantom or matte renders as forced. Understand that matte can be tricky but i hope atleast phantom can work. We want shadows or light from vdb to be seen in our renderpasses.
    Regards Alexis
    http://goodbyekansasstudios.com/
    Hey, Alexis,
    sorry for the delayed response. Yes, Phantom seems doable. Currently it works if added as Object Properties on the node holding the volume - you can disable Primary Visibility to get the same effect. We should be able to link those.
    Matte would be trickier, though. I'll keep you posted with any developments in that area.
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Phantom is enough for us now so if it would work in the rop it would be good. Thanks for the answer!
      Regards Alexis
        Hey, Alexis,
        this should be fixed in the next nightly build.
        Hope that helps!
          will help alot thanks for fast fix!
