Vray works but Console gives Errors on startup and Houdini help does not show up after installing - Houdini 18.0.391
  • Vray works but Console gives Errors on startup and Houdini help does not show up after installing - Houdini 18.0.391
    I installed vray by modifying the houdini.env file like that:
    Vray works without problems but its printing some erros to the console on startup.
    I also noticed that the help inside Houdini will not work if I have installed vray. If I remove the vray installation from the .env file the help works again.
    I would appreciate some help about that.
    kind regards
    Jon
    Sorry....didn“t checked the forum that much and postet that a little to quick.
    I got some help from this thread.
    What I did now:
    PYTHONPATH="${VRAY_APPSDK}/python27;${PYTHONPATH}"
    ...to the end of the env file. That removed the VFH Errors.
    I changed the PATH entry to :
    PATH="${VFH_PATH};${PATH}"
    vs
    PATH="${PATH};${VFH_PATH}"
    that made the help come up again.
    Still getting this errors:
    VFH [Info] * Build number:6698 hash:f2f25ad from 24 Mar 2020 04:59
    PDG Type Registry: Failed to import duplicate module 'houdini' which was previously imported from 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\houdini'
    PDG Type Registry: Failed to import duplicate module 'partitioners' which was previously imported from 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\partitioners'
    PDG Type Registry: Failed to import duplicate module 'schedulers' which was previously imported from 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\schedulers'
    PDG Type Registry: Failed to import duplicate module 'utils' which was previously imported from 'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.391/houdini/pdg/types\utils'
      I've messaged SideFX about this already - those errors only show up if ${PYTHONPATH} is appended back to itself, as in your post. If you append it multiple times, you'll get those errors printed multiple times.
      The PDG errors are benign - they won't cause you any trouble.
      I'm hoping it'll be resolved soon. Not much we can do on our end - I've got SideFX labs and Deadline throwing the same errors here when V-Ray is not present anywhere in the environment variables setup.
      Hope that helps!
      gosho.genchev@chaosgroup.com
        change
        HOUDINI_PATH="${VFH_HOME};${HOUDINI_PATH};&"
        to
        HOUDINI_PATH="${VFH_HOME};&"
          Okay now I dont have any errors and the help File shows up. Nice.
          Do I have to be aware of anything else is/behaves different now ? Since Im not totaly sure "what" I did or why the help shows up if I invert a line in the env file.
          Thank you both.
          I changed red to green.
          Code:
          # V-Ray for Houdini Begin
          VFH_ROOT="//SVG-DS01/software/vrayHoudini_nightly/18_0_391_6698"
          VRAY_APPSDK="${VFH_ROOT}/appsdk"
          VRAY_OSL_PATH="${VRAY_APPSDK}/bin"
          VRAY_UI_DS_PATH="${VFH_ROOT}/ui"
          VFH_HOME="${VFH_ROOT}/vfh_home"
          VFH_PATH="${VFH_HOME}/bin;${VRAY_APPSDK}/bin"
          [COLOR=#FF0000]#PATH="${VFH_PATH};${PATH}"[/COLOR]
          [COLOR=#008000]PATH="${PATH};${VFH_PATH}"[/COLOR]
          [COLOR=#FF0000]#HOUDINI_PATH="${VFH_HOME};${HOUDINI_PATH};&"[/COLOR]
          [COLOR=#008000]HOUDINI_PATH="${VFH_HOME};&" [/COLOR]
          HOUDINI13_VOLUME_COMPATIBILITY=1
          HDF5_DISABLE_VERSION_CHECK=1
          [COLOR=#008000]PYTHONPATH="${VRAY_APPSDK}/python27;${PYTHONPATH}"[/COLOR]
          # V-Ray for Houdini End
