Hello Mr.Hoo , this is how V-Ray understands $F4. This shouldn't be a problem for files names. In order to check the problem I'll need the whole file path expression you are using.
Standalone per frame
we are using Royal Render to submit the written vrscenes. The submit plugin reads the filepath written in the vrscene and this leads to a wrong image file path output:
in the vrscene:
img_file="Oelfilter_test.v003.001.<reName>.<frame0 4>.exr";
img_dir="*censored*/Oelfilter/test/houdini/render/";
in submitter:
../*censored*/Oelfilter_test_test.v003.001.<frame04>.exr
but it expects:
../*censored*/Oelfilter_test_test.v003.001.0001.exr
Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
Well may be Royal Render need to support this syntax then?
- Likes 1
Originally posted by bdancer View PostWell may be Royal Render need to support this syntax then?Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
