Raw GI render element odd behavior
  • Raw GI render element odd behavior
    Hey,
    The Raw GI render element changes completely depending on if a GI render element exists or not. This happens with all scenes
    From my testing it looks like the Raw GI renders correctly when a GI element is present.
    Steps to reproduce,
    -Use my shaderball scene here,
    -Swap render engine to CPU, and check Use Render elements/Use VFB
    -Go to outputs/vray_render_channels1 , It has some render elements setup, just add Raw GI render element
    -Now start the IPR/Production rendering, The Raw GI element would look like this
Name:	Annotation 2020-04-03 110637.jpg
    -Now stop the IPR and delete the GI render element, then start the IPR. This is how the Raw GI looks like now
Name:	Annotation 2020-04-03 110757.jpg
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    Something else about the premade templates, "back to beauty advanced"
    It uses RawDiffuse, RawReflection Filter, and RawRefraction Filter
    Isn't the correct setup Diffuse, Reflection Filter and Refraction Filter?
    Because RawReflection Filter for example, doesn't use any fresnel??
    Or is there a different workflow to comp Beauty using RawReflection Filter somehow? Can someone explain?
    Muhammed Hamed
    chaos.com
      You can check how to use "Back to Beauty" and "Back to Beauty Advanced" here:
      https://docs.chaosgroup.com/display/..._Color-b2bComp
      Georgy Chakarov | QA
      www.chaosgroup.com
      georgy.chakarov@chaosgroup.com
        chakarov Well yeah, in the link Diffuse Filter, Reflection Filter, and Refraction Filter are used
        Not Raw Diffuse, RawReflection Filter, RawRefraction Filter...(which the template uses)
        You cannot get Reflection from multiplying RawReflection Filter and RawReflection (again, RAWReflection Filter doesn't use any fresnel)
        It has to be Reflection Fitler X RawReflection
        Muhammed Hamed
        chaos.com
          Looks like the template has some wrong elements, I`ll fix them for next nightly.
          www.chaosgroup.com
            Thank you!
            On using the 3 correct elements I mentioned, the comp works nicely
            Unless you hit the first issue I explained in my original post. Let me know if you can reporoduce that
            Here is the setup in Nuke(After avoiding the RawGI issue)
Name:	Annotation 2020-04-03 115556.jpg
            Muhammed Hamed
            chaos.com
              What is your OS, Houdini and V-Ray build ?
              www.chaosgroup.com
                Windows 10
                Houdini 17.5.460
                the nightly from yesterday
                vray_adv_43002_houdini17.5.460_fe3ffda_6790_instal l_windows
                Muhammed Hamed
                chaos.com
                  RawReflections, has the same behavoir
                  The only difference between the 2 renders is that I added a GI and Reflection passes, this magically makes RawGI and RawReflections render correctly
Name:	Annotation 2020-04-03 124044.jpg
Name:	Annotation 2020-04-03 124026.jpg
                  Muhammed Hamed
                  chaos.com
                    Well seems this is not a bug.
                    https://docs.chaosgroup.com/display/...ender+Elements
                    In help page is written that rawGI works with enabled GI element. I guess this is valid for rawReflection also.
                    www.chaosgroup.com
                      Ahhhhh
                      Thank you!
                      I came by this page multiple times today and never paid attention to the note :I sorry
                      Maybe if the note was in Red bold text, I could have seen that. or I just need more sleep
                      It definitely didn't work like that in the past. Last year I was using Next for Maya without bothering with the reflection or GI passes. Good to know how this works now
                      Muhammed Hamed
                      chaos.com
