We have a setup with some parameter expressions in the vray rop node. It seems that this expressions are ignored if we export our vrscenes. That is currently a big problem for us.
Here you can see we link the renderlights and the camera with expressions to the timeline.(switcher is linked to the timeline ) The connection works like expected if you change the frames and check the expressions if you have the scene open.
We did create a example file to reproduce that behavior with some sticky Notes.
It would be nice to have a rough estimation how fast that could be fixed or if there is a workaround for that. ( If this isn“t a mistake on our side of course
Thank you very much and kind regards
Jon
- If you render the vray scenes Frame 1-3 as Frame Range than this expressions seem not to update.
- If you render the vray scenes frame by frame the light expressions seem to work bot not the camera.
Jon
