Thank you Gosho. One step closer !!
Firstly I get the following errors on scene load.
Load warnings for C:/Users/jmeston/Desktop/forum_1070445_HQSubmit_envVars.hip
Warning:
/out/vray:
Skipping unrecognized parameter "UVWGenChannel_uvw_transform".
Skipping unrecognized parameter "UVWGenChannel_uvw_transform_tex".
Skipping unrecognized parameter "UVWGenChannel_tex_transform".
Skipping unrecognized parameter "reset_current_vfb".
Skipping unrecognized parameter "geom_export_proxy_mesh".
Secondly the quadruple \\\\ seems to make all the difference, as with just 2 it goes back to previous behaviour.
It is trying to render all the frames, and it succeeds on 1 workstation. It fails on the workstation I am launching the job from, the one with GUI houdini open
See attached image
Checking the successful renders all seems well. They look how they should.
I attach also the diagnostics for the fail.
Highlights here...
Warning: Multiple primitive definitions for: VRaySceneRef
14904: Fatal error: Segmentation fault
I am running Houdini 18.0.460 and "vray_adv_43003_houdini18.0.416_18b5bdd_7012.e xe".
It works fine rendering locally (workstation39) and as can be seen it also renders on workstation36. It just isn't rendering on workstation39 through HQueue with vray. (All is well in Mantra world).
I can't imagine trying to install HQ remotely
Thanks for your help on this, I really need to get some renders going. Feeling the pressure from upstairs!
Best,
Jim
Warning:
/out/vray:
See attached image
Highlights here...
Best,
Jim
