(Fixed) [HOU-1905] volumetric geometry RE
  • (Fixed) [HOU-1905] volumetric geometry RE
    Seems like some RE that should work for volumes in geometry mode are not working as expected. As per docs :
    Multimatte, Objects Select, Object ID, should all work , but none of them does. Only way i`m able to select volumes is cryptomatte now, which is not great(low precision/AA behind glass in my case).
    Can we get some of these RE working?
    thank you!
    Noemotion.net - www.noemotion.net
    Peter Sanitra - www.psanitra.com
    Noemotionhdrs.net - www.noemotionhdrs.net
    Hey Peter,
    indeed, the IDs are put in the wrong place thus the empty pixels for the volumes. We'll fix it.
    Thank you!
    gosho.genchev@chaosgroup.com
      Hey Peter,
      we've fixed the IDs export problem - the MultiMatte and ObjectID elements should work properly now. There's still the issue with the Object Select which will take longer to resolve as it's not specific to VRay for Houdini - I'll message back with more information.
      Best regards!
        Gosho.Genchev Great! is that already inside today nightly build? Or just next one?
          Hey, Peter,
          it's fixed in today's builds.
          Best regards!
