promote parameters to an hda messes with objects
  • promote parameters to an hda messes with objects
    if i promote renderable parameter for 3 objects up to the subnet and the make an HDA of the subnet and the i untick the renderable parameter for 1 of them all gets hidden and not only the geo its connected to.
    we do are lookdevs in HDAs and want to have override control in the lighting scenes without breaking the asset.
    https://drive.google.com/file/d/1fpE...ew?usp=sharing
    Regards Alexis
    http://goodbyekansasstudios.com/
    Well, this is how it works, we go up the hierarchy and adding/merging parameter values.
    The issue is parameter name "vray_renderable" which becomes shared by all objects.
    To fix this you need to rename parameter "vray_renderable" to "vray_renderable1" (like u did for vray_renderable2 and vray_renderable3 for other objects).
    andrei.izrantcev@chaos.com
    Support Request
      I understand. Is there somehow this could work? usually the object properties down the hierarchy have precedence over the top node(like in maya), but maybe that is not even the issue here.
      Btw tried renaming the sphere parameter to vray_renderable1 but didnt get it to work.
        Not sphere parameter, the parameter on HDA node.
        Support Request
          Ah! allright! thought they just had to have unique names but if one has the default name it will get merged into that one? why not let them always have the unique behaviour? probably a good reason, just curious.
            They have, just your setup messes names.
            It's because of this particular setup.
            Promoting parameters makes channel links.
            So in this setup you have channel linking:
            1. "vray_renderable" from bottom node to "vray_renderable" top node
            2. "vray_renderable" from bottom node to "vray_renderable1" top node
            3. "vray_renderable" from bottom node to "vray_renderable2" top node
            After that "vray_renderable" is evaluated and in the current implementation bottom node looks for top node "vray_renderable" without any links, just walks the hierarchy.
            That's why vray_renderable on top node overrides all. And that's why renaming it to "vray_renderable1" makes it work, because then only channel link is effective.
            Support Request
              That was some good eli5 thanks! Now i know how to solve it. I guess my request then is top to bottom but understand if it's not a goal to change that.
              Regards alexis
