Background Image VFB :: UI glitches in buttons // VFB not remembering the file path
  • Background Image VFB :: UI glitches in buttons // VFB not remembering the file path
    1. I have some minor UI glitches in the "correction controls" buttons.
    See attached image
    2. When a file was load as BG it is blank after reopening the VFB. I don't have this behavior in Maya, where it always remembers the last used BG file path, even after reopening Maya
    Win 10
    Houdini 18.0.499
    Vray 4.3.003 7598
    Tell me what you need to investigate further
    Thx for your feedback
    cheers
    Dominik
    Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
    Hi Mr.Hoo , you should use "VFB Background image" in Images tab of the V-Ray ROP. There you could use expressions as well.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Ahhh ok, thx for this hint!
      I will use it.
      But would it make sense, to get rid of the buttons in VFB itself then?
        It will, but it's not possible now, unfortunately.
        andrei.izrantcev@chaos.com
        Support Request
          Alright ! Thanks for clarifying
