(Fixed) Unresponsive VFB during rendering
  • (Fixed) Unresponsive VFB during rendering
    Often I find that the VFB stops updating during rendering. Sometimes zooming in and out will trigger an update but not always.
    reducing threads to numthreads-1 and setting render priority to low doesn't help.
    Sometimes Houdini will completely hang until the render finishes, then it will act normal again.
    build 18.0.566
    vray_adv_43003_houdini18.0.566_babb3a1_8139
    Any ideas?
    R
    Operating system?
    andrei.izrantcev@chaos.com
    Support Request
      same here, win10
        Also the same happens here. This only happens when using bucker render, IPR does not have this issue. My work around was to click the follow cursor button on and off, this seems to cause the VFB to refresh.
        Windows 10 here also, and this phenomenon has been happening for several versions of VFH (months back). Our Houdini version is 18.0.397.
        Best,
        David.
        David Anastácio // Accenture Song - VFX
        https://www.accenture.com/us-en/serv...visual-effects
          Originally posted by bdancer View Post
          Operating system?
          Sorry, forgot to add = Windows 10
            Yeah, this has been happening for a while and I believe it has been reported before.
            Win 10 as well
              Hey all,
              could you please confirm that this does not happen for you if no output connections are present for the Renderer ROP? This only happens for me if the ROP is hooked up to e.g. a Deadline ROP or even a Null.
              Best regards!
              gosho.genchev@chaosgroup.com
                Ha, yes, I can confirm (using the thinkbox deadline node here). This actually also affects the Log Window (which sometimes also does not update).
                  Originally posted by Gosho.Genchev View Post
                  Hey all,
                  Best regards!
                  Yes, all ROP nodes are linked to something (our custom deadline submitter node).
                  Best,
                  David.
                    Yes, Same here deadline Rop or null
                      yeah hooked up to deadline node for me.
                        same here,
                        I posted a similar issue here:
                        https://forums.chaosgroup.com/forum/...reraction-lags
                        Win 10
                        cheers
                        Dominik
                        P.S.
                        Hey all,
                        Best regards!
                        maybe, I have to check older projects, where this happened
                        Dominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
                          I'm assuming this is fixed, right bdancer ?
                          Just tested with the latest nightly and at first look no issues anymore with the V-Ray ROP connect to something.
                          Best,
                          David.
                            There were some fixes added, yes.
                            Support Request
                              Great, thanks
