[HOU-3941, HOU-3939] Vray Fur distribuition
    And the build used was:
    V-Ray for Houdini number:22483 hash:b0681b5 from 16 Aug 2023 01:33
    V-Ray Core 6.10.09 [2acfc729] from 11 Aug 2023​
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
      Thank you, david_anastcio Wanted to make sure it's 100% the same scene and you have not made any changes. I have shared the information with the Developers.
        Originally posted by viktor_angelov View Post
        Hello david.anastacio
        I would like to inform you that the V-Ray Fur Distribution Slider has now been upgraded.
        Please, test it in our latest Nightly build and feel free to share any feedback you may have: https://nightlies.chaos.com/main#/vray6houdini/nightly
        viktor_angelov, in this post here, you said that the distribution slider was fixed, but is this really working as intended? The slider in the UI still default to 0-1 range, and when using it you need to push the value way above that range, into the millions.
        In the following example I need to pushed the distribution all the way up to 40M to get a decent amount on a face:
        What is the area? Is it the whole object? Is it a specific size, like a 1 meter square? Are this values expected?
        Best,
        David.
