vraySSS - Inputs
  • vraySSS - Inputs
    I noticed the vraySSS "Scatter Color" parameter has its input name wrong, it's called "scatter_radius".
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
    Hey David,
    the input name is correct, rather it's the UI labels that we had a hard time with - those need to change based on the "Color Mode" parameter, as they do in 3ds Max. I suppose we will update those as well once we figure out what to do with the V-Ray material's Reflection Glossiness/Roughness parameter that also doesn't change labels at the moment.
    // in case you're wondering why we did not do that in the first place - it would involve adding 2 dummy parameters that are visible in the UI, and driving the real, third one with python expressions. We could easily cause a mess if we're not careful.
    Best regards!
    gosho.genchev@chaosgroup.com
