(Fixed) [HOU-2249] Image node error
  • (Fixed) [HOU-2249] Image node error
    There's another issue with the image node in this latest VFH version. When adding an image to it, it always throws this error now:
    Click image for larger version  Name:	imageNode.JPG Views:	46 Size:	25.4 KB ID:	1092517
    VFH version:
    Click image for larger version  Name:	vfh.JPG Views:	56 Size:	3.1 KB ID:	1092516
    Best,
    David.
    David Anastácio // Accenture Song - VFX
    https://www.accenture.com/us-en/serv...visual-effects
    Hi
    Can you please describe what steps do you take to reproduce this? This is linked to auto selection of color space based on the file name. Seems like there is mismatch between your .ds file and python.
      Hi poseidon4o
      Empty scene and just added an image node in /mat, loaded a texture, error pops up.
      The same steps in an older version of vray do not lead to this issue, as seen in this screengrab:
      Best,
      ​​​​​​​David.
        Hey David,
        the problem should be resolved in the latest nightly build. We had some V-Ray 5 code for automatically choosing the transfer function interfering with V-Ray 4.3
        Hope that helps!
        gosho.genchev@chaosgroup.com
          Originally posted by Gosho.Genchev View Post
          Hey David,
          Hope that helps!
          Awesome, that's highly appeciated, thanks
            Hi Gosho.Genchev, I confirm that this issue is resolved, thanks to you and the team.
            Best,
            David.
