(Fixed) [HOU-2330] Vray5 Fire volume broken ?
  • (Fixed) [HOU-2330] Vray5 Fire volume broken ?
    Hi, looks like fire in volume grid shader isn't work at all.
    I can put any volume, with density temperature flame etc.. even creating temperature with volume wrangle . it's not fire.
    Smoke work fine, so i know density is here and work, so i put the density in fire field to give a try, put the multiplier to 100000000 and there is always no fire at all.
    is it broken ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    I checked with Vray 4. It's work with Vray4. not with vray 5. so, Vray 5 fire is broken
    freelance 3D artist
    www.ghiom.com
      There is anybody here from chaosgroup to check this ? Volume Fire is missing in the release.
      freelance 3D artist
      www.ghiom.com
        Hey ghiom3d ,
        That is correct, one of the parameters on the Volume Grid shader is not being exported. We'll likely update the builds or drop a hotfix. In case it is urgent for you, the following Renderer ROP -> Post-Translate script will force the export:
        PHP Code:
        import vray
        with vray
        .VRayRenderer() as v:
            for
        p in v.plugins:
                if
        p.getType()=='PhxShaderSim':
        p.earg=
        Hope that helps!
        gosho.genchev@chaosgroup.com
          Thanks you
          freelance 3D artist
          www.ghiom.com
            Hey ghiom3d ,
            The export issue is resolved in the nightly builds.
            Best regards!
              Originally posted by Gosho.Genchev View Post
              Hey ghiom3d ,
              Best regards!
              I don't see any Nightlies of VRAY 5 in Nightlies space.
              freelance 3D artist
              www.ghiom.com
                Hey ghiom3d ,
                Best regards!
                Hi Gosho.Genchev, same issue as ghiom3d here, no nightlies in the nightlies page.
                Best,
                David.
                David Anastácio // Accenture Song - VFX
                https://www.accenture.com/us-en/serv...visual-effects
                  Hey david.anastacio , ghiom3d ,
                  I'll message the support team right away - it looks like you do not have access to the builds.
                  Best regards!
                    Gosho.Genchev Can you please add me as well? Thanks!
                    Noemotion.net - www.noemotion.net
                    Peter Sanitra - www.psanitra.com
                    Noemotionhdrs.net - www.noemotionhdrs.net
                      Hey Peter,
                      I've just emailed the colleagues for you as well.
                      Best regards!
                        The same here, please. Not access to nightlies. THanks
                          I only have access to the nightlies of version 4, not 5.
                          Please add me, too
                          Thanks
                            Hey hsz , pixeltrain ,
                            I've emailed the colleagues, you should shortly be set up with access to the nightlies.
                            Best regards!
                            • #15
                              Hello, can you add me too? I have an issue with volume render!
