What is up with the curvature node? Doesn't seem to be working very well at the moment.
Trying to use on some simple geo gives mixed results.
Geo setup with a default dirt:
Not the result I expected. Plus the size difference in the boxes seems to give different result on the curvature.
With a more complex geometry and with default settings. Fiddling with the setting can't really get the desired result too.
Same geometry in 3dsMax and default curvature settings. Far from perfect also, but at least is getting somewhere.
And this is a result of a "Labs Measure Curvature", more of what I expect to see happening out of a curvature attribute.
So, is the V-Ray curvature node working correctly? Is there anything that can be done to improve its results?
Best,
David.
Best,
David.
