(Fixed) [HOU-2373] New frame buffer gives QT errors
  • (Fixed) [HOU-2373] New frame buffer gives QT errors
    Hi. Just got upgraded to Houdini 18.5.408 + VRay 5 and started poking around. When I add post processing items in the frame buffer (LUT, exposure) I get these errors:
    "Qt Warn: QPainter::begin: Paint device returned engine == 0, type: 3
    Qt Warn: QPainter::setCompositionMode: Painter not active
    Qt Warn: QPainter::end: Painter not active, aborted"
    It mostly seems to work anyway, but sometimes values reset and the exposure node has disappeared a couple of times. I haven't found anyone else with the same problems, should I ask to reinstall everything or is this a known bug? I still have old versions of Houdini and VRay installed, if it makes any difference.
    Hey Monkeybrother ,
    We've known about the issue for a while but never noticed broken functionality so the priority for a fix was low. I'll see if I can reproduce the issues you've mentioned and get back to you.
    I assume re-installing will not solve the problem, neither would removing old Houdini/V-Ray versions.
    Best regards!
    gosho.genchev@chaosgroup.com
      I have the same issue btw om Vray 5 as well and is just when you use the VFB
        I am sorry to jumping into this. But I am having the exact same issue. Can anyone advise ?
          Same problem here. Maybe its not broken but it is very annoying.
          www.gaell.com
