Hi!
We would like the texture color management to be exclusively handled by the OCIO settings on the image file node when its enabled.
There is as of vray 5 three parameters controlling texture color management.
To us it makes sense to disable any effect of the two bitmap buffer settings when the ocio settings are enabled. Disable in this case setting them to None and Raw respectively.
Cheers!
/Hannes
- BitmapBuffer_color_space
- BitmapBuffer_rgb_color_space
- All the settings under the OCIO tab.
Cheers!
/Hannes
