Motion blur not working on meshed fluid sim
  • Motion blur not working on meshed fluid sim
    Motion blur not working on meshed fluid sim.
    I have velocity attrib but I am getting no motion blur and / or no RE velocity pass (well its rendering blank)...
    Any help appreciated
    Hey Jim,
    Could you please check if the Geometry node -> Render -> Sampling -> Geometry Velocity Blur is set to "Velocity" ?
    Best regards!
    gosho.genchev@chaosgroup.com
      How embarrassing
        One more question if I may...
        How do you calculate what the max velocity or velocity range should be in the RE_velocity pass ??
        it seems arbitrary or do you just save as 32bit and it just works?
          Hey Jim,
          Indeed, if you need to clamp it, I can't think of a way for us to handle this automagically - you'd need to set the Max Velocity manually.
          Best regards!
            OK so if I am saving 16bit exrs how do I approach that setting? What are the units? Is it the magnitude of the vector as accessible in Houdinis geo spreadsheet?
