Fire issue
  • Fire issue
    Hello, do you have an idea about my issue, my scene is on vray render and I can visualize the fire on my render.
    just see the following printscreen:
    Probably your emissive volume is not named 'heat' but something else, temperature or burn - look in the info or geometry spreadsheet
    Hristo Velev
    MD/FX Lead, Bottleship VFX
    Sofia, Bulgaria
      I don't understand... sorry
        Hey sbastien_levieux ,
        I assume you're using V-Ray 5 - we did some changes near the release date that caused an issue with the export for the emissive (fire) component of the shader. The issue is resolved for the nightly builds - I've messaged the support team with your email in CC so you can grab a nightly build once they provide you with access.
        In case you'd rather use the official download, you could add this to the Post-Translate tab of the V-Ray Renderer ROP:
        import vray
        with vray.VRayRenderer() as v:
        for p in v.plugins:
        if p.getType()=='PhxShaderSim':
        p.earg=1
        Click image for larger version  Name:	houdinifx_2021-02-08_01-14-48.png Views:	0 Size:	65.3 KB ID:	1101722
        Best regards!
        gosho.genchev@chaosgroup.com
          Thank you Gosho for your mail and your message, I did the post translate but I steel have no fire in the render... Click image for larger version
            @sbastien_levieux , you should keep indents in code, otherwise python won't work.
            Georgy Chakarov | QA
            www.chaosgroup.com
            georgy.chakarov@chaosgroup.com
              @chakarov, I think it is working, I install the different release:
              Look at the result:
