shader pyro issue
  • shader pyro issue
    I have an issue for the fire render, if I turn off the smoke in the shader, the fire disappear in the render: Difficult to devlook the fire!
    Hey sbastien_levieux ,
    If the Fire -> Opacity Mode is set to "Use Smoke Opacity", it will only be visible if the rendering of smoke is enabled. Could you please check the Mode in the Fire tab to make sure ?
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Thanks Gosho, i will check and give to you a feedback!
        It works only with this option!
