Vray TOP errors - not working
  • Vray TOP errors - not working
    I am installed vray_adv_50050_houdini18.5.351 and vray_adv_50050_houdini18.5.408 and while both work fine in manual mode they both give me tons of errors while using VrayTOP. I also edited _init__.py to include hou as advised by forum post I came across. Any ideas to why it wouldn't work ?
    Thank you
Name:	Screenshot from 2021-04-15 12-05-38.png
    V_Ray top node is a ropfetch and a V-Ray rop under the hood. Try using them instead of V-Ray top.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Did you install V-Ray for Houdini or you are using some kind of version control software, or may be V-Ray is loaded via houdini.env file ?
      Can you share a hip file with the problem ?
      www.chaosgroup.com
