Image file node expression issue
  • Image file node expression issue
    Hi!
    Im using an expression for the file parameter (1) on the vray_image_file node. That expression looks up another parameter (2) also using an expression that looks up a 3rd parameter. In my case this does not work. The file name output to the vrscene is empty. In houdin middle mouse button on the parameter (1) returns the right path though.
    Attached simple scene.
    Cheers!
    /Hannes
    Linux centos
    Houdini 18.5.499
    V-Ray for Houdini number:12295 hash:6ff5fd0 from 14 May 2021 16:30 (build number:12295)
    V-Ray Core 5.10.03 [08490499] from 14 May 2021
    Head of Lighting @ Goodbye Kansas Studios
    Tnx, will work in the next nightly.
    andrei.izrantcev@chaos.com
    Support Request
