In Maya if you scale the Locator for an IES light, it will scale the light distribution of the light to match. If I do the same in Houdini it has no effect, would it be possible to get the same behavior? Also in Maya when an .ies file is loaded the Locator is scaled to matched the size light from the file, in Houdini the viewport geometry is always the same size.
This is using:
Vray version 5.10.20
Houdini 18.5.586
Thank you
This is using:
Houdini 18.5.586
Thank you
