( Resolved ) Houdini Indie 18.5.596 crash
  • ( Resolved ) Houdini Indie 18.5.596 crash
    In Houdini Indie 18.5.596 even in new scene with just one box, when I hit render I receive this error
    3140: Fatal error: Segmentation fault
    What is your V-Ray build number, did you manually set it up or with installer ? Is your Houdini a python 3 build ? Are there any messages when creating a V-Ray ROP ? You could use V-Ray menu > About V-Ray to check V-Ray build number.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Vray lsatest from website that I installed with installer
      V-Ray for Houdini hash:fb365cd from 16 Jun 2021 11:46
      V-Ray Core 5.10.20 [5322b47e] from 4 Jun 2021.
      Houdini not python 3
      Only one message appear: Fatal error: Segmentation fault
        Are you using VFH build exactly for .596?
        andrei.izrantcev@chaos.com
        Support Request
          Yes. Just re-installed it to make sure. The problem stay
            If you have access to nightlies https://nightlies.chaosgroup.com/#/vray5houdini/nightly could you pls try a build from there?
            Support Request
              just tried latest build, it's not help
                Dear Mikhalenko, hello.
                Please confirm the following:
                • You aren't able to render even a simple geometry with Houdini Indie 18.5.596 (python 2.7) and V-Ray 5, update 1
                • You are successfully using V-Ray with 18.5.499 (information gathered from a test scene provided by you)
                The best thing will be to agree for a TeamViewer session to provide you live support.
                Just say yes and I will send you online calendar to choose appropriate time.
                Tsvetomira Girginova | chaos.com
                3D Support (AEC,HOU,C4D) Team Lead | contact us
                  Hello.
                  Yes and yes, and yes for the TeamViewer
                    Great, thank you.
                    PM sent.
