( Resolved ) banding issue in VFB
  • ( Resolved ) banding issue in VFB
    The issue seems to have start between V-Ray Core 5.10.03 and V-Ray Core 5.10.20.
    Here I use the latest ACES 1.2 from https://github.com/colour-science/OpenColorIO-Configs
    and as you can see that since V-Ray Core 5.10.20 banding artifacts started to appear
    houdini 18.5.499
    linux centos, cinnamon
    to the left is:
    V-Ray for Houdini number:12523 hash:fba7db2 from 25 May 2021 02:03 (build number:12523)
    V-Ray Core 5.10.03 [fefb5099] from 19 May 2021
    to the right is:
    V-Ray for Houdini number:14462 hash:8cd7621 from 05 Aug 2021 02:02 (build number:14462)
    V-Ray Core 5.10.20 [df34ddfc] from 2 Aug 2021
    http://goodbyekansasstudios.com/
    Dear LeoYfver, hello.
    We are investigating some banding issues when low-intensity lights are used, so you are right on time.
    It will be very helpful to share the lighting setup or a test scene, that you have used.
    That way I will perform the very same test - for now I am not able to reproduce such a clear difference.
    Thank you in advance.
    TS
    3D Support (AEC,HOU,C4D) Team Lead | contact us
      here is the file. Btw as a sidenote the scene crashes often when either moving or pressing a button in the VFB.
      Regards Alexis
        Thеn 2 in 1 for looking at.
        Thank you!
          I am also seeing this issue in some renders using the scattering shader.
            Happy to announce that the described from LeoYfver banding is handled in nightlies.
            Please check the latest (from today).
            I have just tested it both on win & linux and could confirm.
            Dubbie99, please give the mentioned build a try.
            If you are still experiencing it, we will need more information and run more tests.
            Thank you both.
            Wishing you happy Friday the 13th.
              tsvetomira.girginova thank you will will probably try it next week.
              and happy friday 13th to you too :P
