Vray PDG Render Node Error - No Cook or Work-items - Skipping unrecognized parameter "folder_secondary_bounces"
  • Vray PDG Render Node Error - No Cook or Work-items - Skipping unrecognized parameter "folder_secondary_bounces"
    Hello,
    i have problems with the V-RAY PDG ROP. It won't cook or generate workitems or give any further response at all, only during startup of the file:
    HTML Code:
    Warnings were generated during load.
    Error loading: /.../.../syntheticFlights.hiplc
    Warning: Problem while synchronizing child node:
    Warning: Unknown channel(s) "vfh_is_gpu, SettingsOutput_img_clearMode, SettingsDMCGI_subdivs" converted to spare parameter(s).
    [/tasks/synthetic_data_generator/ropvray2/VRayROPNet/VRay]
    Warning: Skipping unrecognized parameter "folder_secondary_bounces".
    Skipping unrecognized parameter "folder_camera_stereoscopic_simmode".
    If I manually use a Ropfetch it is painfully slow to render, much slower than if I manually render from the Vray ROP.
    Is this a bug or can I fix it somehow? I am running out of time for a project, so I would appreciate an answer.
    Thank you and kind regards from your beautiful country of Bulgaria!
    David
