Is anyone else getting this issue. If I have the V-Ray for Houdini package active, the Karma LOP will not render. It seems to just fail silently on each frame. If I deactivate the V-Ray for Houdini package, the Karma Lop works fine again.
This is my vray.json package file:
Code:
{ "enable": "houdini_version == '18.5.499'", "env": [[INDENT]{ "INSTALL_ROOT" : "${ENV_ROOT}/vray_adv_51020_houdini18.5.499" }, { "VRAY_APPSDK" : "${INSTALL_ROOT}/appsdk" }, { "VRAY_OSL_PATH" : "${INSTALL_ROOT}/appsdk/bin" }, { "VRAY_UI_DS_PATH" : "${INSTALL_ROOT}/ui" }, { "VFH_HOME" : "${INSTALL_ROOT}/vfh_home" }, {[/INDENT][INDENT=2]"PYTHONPATH": {[/INDENT][INDENT=3]"method": "append", "value": [[/INDENT][INDENT=4]"${INSTALL_ROOT}/appsdk/python37"[/INDENT][INDENT=4]][/INDENT][INDENT=2]}[/INDENT][INDENT]}, {[/INDENT][INDENT=2]"PATH": {[/INDENT][INDENT=3]"method": "append", "value": [[/INDENT][INDENT=4]"${HFS}/bin", "${VRAY_APPSDK}/bin", "${VFH_HOME}/bin"[/INDENT][INDENT=4]][/INDENT][INDENT=2]}[/INDENT][INDENT]}, { "HOUDINI_GALLERY_PATH": ["${HOUDINI_GALLERY_PATH}", "${VFH_HOME}/gallery"] }[/INDENT] ], "path" : "${VFH_HOME}" }
