PDG Error
  • PDG Error
    Hi There, I'm having a problem using Vray in PDG.
    I've got everything rendering fine, but when I re-cook the node it Re-Renders everything that has already been rendered instead of realizing that it's already on disk.
    I get an error in the Rop Fetch node that says unable to find output param for /out/vray but I don't understand how that can be if it is rendering to disk.
    Any help would be greatly appreciated.
    Cheers.
    I found a way to override the output path you have to select Output Param Name from the ROP Fetch Node and in that field you type: SettingsOutput_img_file_path
    Just FYI for anyone else with the same problem
      Dear chadstevens, hello.
      Yes, due to some SideFX changes the name should be edited. We are aware.
      If someone encounters difficulties of editing it, I will explain it in steps + visual:
      • RMB over the node > Allow editing of Contents (the padlock will open) like this
      • open it and edit Output Parm Name by leaving only SettingsOutput_img_file_path like this
      • start Cooking
      Thanks again for sharing with the community.
      You have figure it out in five minutes, so - well done!
      Tsvetomira Girginova | chaos.com
      3D Support (AEC,HOU,C4D) Team Lead | contact us
        Just to add, after double checking it, this is already fixed in our nightly builds.
