Segmentation fault 36076
  • Segmentation fault 36076
    I have 36076 Segmentation Fault, with Houdini crashing. I can't really understand why this is happening.. usually when trigger for a new rendering. Duplicating the Vray Rendering Node seems to avoid Houdini to crash..
    I don't know if there is a Log file somewhere to share..
    V-Ray for Houdini hash:fb365cd from 16 Jun 2021 11:44
    V-Ray Core 5.10.20 [5322b47e] from 4 Jun 2021
    Houdini 18.5.596
    Do you have access to the nightly builds? If not please write to support@chaosgroup.com.
    You may try more recent build to see if this is fixed there.
    andrei.izrantcev@chaos.com
    Support Request
      Hello, regarding this thread and this one too, I have created a ticket in our system.
      The access will be shortly provided.
      Please check again is the issue still there with the nightly builds, as Andrei mentioned.
      Confirm here and if needed we will continue the investigation on this matter.
      Wishing you a wonderful week.
      Tsvetomira Girginova | chaos.com
      3D Support (AEC,HOU,C4D) Team Lead | contact us
        bdancer , thanks I installed the last nightly, but still have the same issue...see attached
          creac, in order to be more helpful, please define the following:
          • is it happening in all scenes (even in newly created ones) <> if yes, it is an installation issue => define .zip ot .exe have you chosen
          • is it happening in particular scene only <> if yes, we will need it to investigate further => use V-Ray > Pack Scene and I will open a ticket where you could send it safely
          Choose your truthful case, waiting for the info.
            Hi tsvetomira.girginova, it is happening when I open an existing file. Not with a particular scene. I just installed the most recent Nightly today and still have the issue. To avoid Houdini to crash I just delete the vray render node and create a new one. Then it works OK.
            How can I checked if the last Nightly is correctly installed? I am just asking because when copying the "About Vray" to give you the version it still June 2021 something.. Shouldn't it be October 2021 instead?, the date of the Nightly release?
              Yes, creac, it should be updated.
              Have you used the .exe or the .zip install?
                tsvetomira.girginova .zip
                vray_adv_43003_houdini17.5.460_17308ea_17953_insta ll_windows.zip
                  @tsvetomira.girginova .I just realized I downloaded vray next 4.30.. nightly. Usually I am working with Vray 5. Is there any Nightly for Vray 5 as well ? I can't see it
                    @tsvetomira.girginova, my mistake I found it!
                      Okay, give it a try and share what happened.
                      Be sure that you have downloaded the right build for your Houdini version. First you have mentioned 18.5.596 and then 17.5.460.
                      If you are experiencing issues, please agree for a TeamViewer session to take a look and help you.
                        Everything seems fine now. no more crashing. Thx
                        V-Ray for Houdini number:17945 hash:829ac5d from 25 Oct 2021 04:53 (build number:17945)
                        V-Ray Core 5.10.20 [cc973758] from 23 Oct 2021
                          Great news!
                          Enjoy V-Ray.
