Issue with motion blur when set to center on frame
  • Issue with motion blur when set to center on frame
    Hi!
    We have found an issue with motion blur when having the shutter interval center set to 0. The setting 0 is a requirement for plate based VFX work as that would match the motion blur in the plate.
    The issue seems to be that packed alembics without displacements are offset in time slightly.
    The following image show the issue:
Name:	Screenshot from 2021-11-03 16-19-09.png
    Top: Ball in houdini without displacement
    Middle: Ball in packed alembic without displacement
    Bottom: Ball in packed alembic with displacement
    Attatching hip and abc file
    motion_blur_issue.zip
    This is pretty urgent for us as we get a mismatch in motion blur between objects. For example fur without displacement not sticking to the skin with displacement.
    Cheers!
    /Hannes
    Head of Lighting @ Goodbye Kansas Studios
    Hey Hannes,
    Looking into this right away. Thanks for pinging us.
    Best regards!
    gosho.genchev@chaosgroup.com
      Heya Hannes,
      I can't reproduce the problem here - I've tried with a build from Oct 1st, and the latest nightly build. It's possible the one you have has a problem, or maybe something was changed in the scene before uploading it.
      Could you please check that the problem is still reproducible with the scene you've attached, and if so - ping me with the build date (from top menu -> V-Ray -> About V-Ray -> Copy to Clipboard)
      Thank you!
        Hi Gosho.Genchev !
        Thanks for looking into this so swiftly.
        And you are right. With a later build this issue is fixed.
        Thank you!
        /Hannes
