Filecache and Motion Blur
  • Filecache and Motion Blur
    Hello guys,
    I have an agent after crowd sim. I intend it to render it with motion blur. It works fine until I cache it.
    The same with animated fur.
    I expected that filecache essentially holds the same info as the cached node. Can I somehow get the motion blur to work?
    I am using H19.383 and Vray 5.10.20 on Linux (PopOS).
    Thanks,
    Vojtech
    Hello woytha ,in order to get motion blur on moving cached meshes you need either to export whole animation in one abc/cache file, either to provide velocity attribute if you want to cache animation per frame. If this does not help, can you upload a simple scene of your scenario.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      Hm, at the end it was something with camera... Not sure what, though. I ended up to recreated new camera with basically same settings and it works fine now (even without computed velocities!)
