Volume Motion blur
  • Volume Motion blur
    HEllo
    I have trouble to render my volumes with motion Blur with RTX
    I setup up my camera , my obj nodes and the vray ROP to do motion blur with velocity.
    My cached volume have the velocity attribute but even i push the multiplier in shader to 100 i don't see anything. My camera have enought time to do motion blur, my meshes are motion blured and move slower than my volume.
    I've try to split the vel attribute to 3 vel.* , but same result.
    i've try in CPU mode, same thing.
    Can you help me?
    Houdini indie 19.0.498 // vray_adv_52020_houdini19.0.498_4507299_20994_insta ll_windows // Win11
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    Hello ghiom3d , seems to work on our end. Can you double check if your velocity volume is scalar or vector one. The "vel.*" expression is for separated X,Y,Z scalar volumes , if your velocity volume is vector one the expression should be "vel". If this doesn't help, can you share your Video Card model and Video Driver version ? Simple scene will help as well.
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      hello Georgy, I have try with a vector velocity, that's how it's saved in my Bgeo.sc volume cache.. and because i don't see any motion blur, even everything seems setuped ok, i've add a node vdbvectorsplit to split vel in vel.x vel.y and vel.z. i will try to do a simple scene for you
      my Nvidia driver is Studio 511.65 on a 3080-ti and 2080
      freelance 3D artist
      www.ghiom.com
        i've find a way to make it work .
        I need to blast temperature, in info temps is [0, 0, 0 ] so i don't use it.
        then i split velocity and density because for optimising my scene, velocity is 1/2 scale of density. that's the way i work since years for now.
        so i use a vdb resemple node to resample my velocity as the same resolution than density.
        then i merge them together
        and i need to convert this reconstructed vdb fog as Volume and not anymore Vdb fog.
        Now motion blur work and i have velocity it in AOVs.
Name:	Capture d’écran 2022-02-03 175904.jpg
        Is my fault was to undersample velocity ? or because we need to convert to Volume instead of VDB FOG ?
        freelance 3D artist
        www.ghiom.com
          and i see i can add again a vdb convert to convert this VOLUME to VDB Fog and it's work .. very strange !
          freelance 3D artist
          www.ghiom.com
            Definitely strange, can you share a scene, even simple one, where the problem occur ?
            www.chaosgroup.com
