Vray Light instancer doesn't work with disc lights.
  • Vray Light instancer doesn't work with disc lights.
    If you set up some instanced vray rectangle lights they work fine. As soon as you switch them to disc, they go weird. Not sure how to explain it.
    For a start whatever their size is is reset to 1.0 whether it is set on the light or by pscale. And secondly, it seems almost like there is a square and a circle in the same place and they self intersect.
    Hey Dubbie99 ,
    Attached here is a scene with V-Ray Rectangle lights instanced over points with pscale and Cd attributes, both using a Geometry node with s@instance attribute and an Instancer object --> LINK.
    Here's a screenshot of the result on my end, with a build from Feb 07.
    Could you please give my scene a go and see if ti works as expected for you?
    Best regards!
    gosho.genchev@chaosgroup.com
