lpe curly brackets
  • lpe curly brackets
    Does curly bracket work in vray lpes? like this for example
    CD{0,10}L
    my goal is to achieve direct and indirect sss. So my gues is that i need to control the diffuse bounce
    direct sss?
    C<TD>.L
    indirect sss?
    C<TD>.{2,}L
    probably thinking about this all wrong :P
    Regards Alexis
    http://goodbyekansasstudios.com/
    Hello LeoYfver , curly brackets are not supported. But you could use a boolean operation as expression, so "(C<TD>.+L)-(C<TD>.L)" should give you SSS without direct SSS
    Georgy Chakarov | QA
    www.chaosgroup.com
    georgy.chakarov@chaosgroup.com
      chakarov thanks so much for this! was scratching my head for along time :P
      could we add curly brackets as a feature request not very important but nice to match lpes as close as possible.
      Regards Alexis
